M
Mindvox
Hi guys, not posted in a long time.
Anyway, I'm selling my LG Plasma on eBay and currently have £500 with 2 days to run. I'm looking at using the money to buy a Samsung LCD, although I have taken the Toshiba 32WLT66 into consideration also.
What I want to ask though, is what's the difference between the Samsung models in the thread title? Cosmetically, I see that the "BX" has a silver trim at the bottom of the set, and the "BD" has a blue tinted trim. However, on Curry's website the "BX" is £629.99 and the "BD" is £689.99, although I have a code to bring the "BD" down to £609.00.
Is there any major performance difference between them? I compared the specs on the website, and noticed that it says the "BX" does not come with a Freeview Digital tuner? However, it also says the "BX" is not flatscreen ... so I don't really want to read too much into Curry's technical spec sheet.
Any info or advice would be appreciated. Although, one other question. I had a look at the Toshiba in Curry's this afternoon, and the sticker on the set said something about full HD and mentioned a resolution of 1900 x 1080 ... yet the set has a native resolution of 1366 x 768, so I take it the sticker is referring to downscaling software? I also heard that the Sammy is better at pixel for pixel mapping via VGA, which is important to me because I need this set primarily for Xbox 360 and HD-DVD.
Cheers.
Cheers.
