Samsung LE32R51B service menu problems
M
mochu
Well I messed up quite badly, yesterday I was trying to do something about poor picture quality in RGB mode and played a little in service menu of my LE32R51B
( Info -> Menu -> Mute -> Power ON)
I have changed everything and nothing could be done about RGB quality in this TV, so I used the build in Reset Command. Unfortunately the reset command does not seem to reset all values :( and here I am begging you for mercy. Flashing the TV with new tearing proof firmware from Samsung also did not help ( the values were preserved ). My picture is all in mess right now. :eek:
Maybe someone knows some secret combination on the remote to reset TV to factory settings ?!
IF not could You give me the values on yours TVs ?! ( what ever is your version LE32R41BDX, LE32R41B, LE32R51BDX, LE32R51B freeview or ROME )
:lease:
White ballance
Sub Brightness ? Sub Contrast ?
R-Offset ? R-Gain ?
G-Offset ? G-Gain ?
B-Offset ? B-Gain ?
SVP-EX
Picture Gain Adjust
TCD3 Contrast ? Analog PB Offset ?
TCD3 Brightness ? Analog PR Offset ?
TCD3 CR ? Analog Y Gain ?
TCD3 CB ? Analog PB Gain ?
TCD3 Delay ? Analog PR Gain ?
Analog Y Offset ? Black Level ?
Svp Brightness ?
MTS 9883
R-Offset ? R-Gain ?
G-Offset ? G-Gain ?
B-Offset ? B-Gain ?
S
smallmanongn
Dont know about LCDs but on CRTs these sorts of settings varied between sets so dont know if someone elses values will do much good but it might be starting point.
Good case for writing these things down before you fiddle :oops:
M
mochu
Yeah when I saw the reset command I was sure I could reset and everything would be fine. :(
