Samsung LE32R41BDX + Soft modded xbox
Discussion in 'Samsung TVs Forum' started by mrback, Oct 26, 2005.
Tags:
  1. mrback
    mrback
    Jun 4, 2005
    432
    +21
    Hello
    Can anyone give me some optimum settings for this tv when using it with an xbox? I have soft modded so it does output 720p on certain games.
    cheers in advance
    Samsung LE32R41BDX
  2. Evil_Homer
    Evil_Homer
    Oct 17, 2005
    144
    19
    Deal
    Sorry, I'm new to all this but how do you soft mod the xbox, I'm running mine through a 32" ??? :lease:
  3. bignige
    bignige
    May 13, 2003
    718
    +32
    You need, an orignal splinter cell disc, action replay or memory card (if you know someone with a modded Xbox) and a couple of files.
    You can load up a program called Enigmah Video Selecter, which will allow you to change your Xbox to NTSC, this & a component lead will allow you to play Xbox games in Hi Def. You can still use XBL as well.
  4. yod9999
    yod9999
    have a look at this thread, all the info is here.
    http://www.avforums.com/forums/showthread.php?t=223051
    if you reply to the list and say that you'd like to have the kit you'll get it when your turn comes round. then you just need to send it on to the next person once you're done.
  5. mrback
    mrback
    Jun 4, 2005
    432
    +21
