Samsung LE32R41BD
Discussion in 'Samsung TVs Forum' started by twiglet, Oct 31, 2005.
Tags:
  1. twiglet
    twiglet
    Mar 2, 2005
    149
    Just brought this tv and was wondering what is the best way to connect my sky + 160 box, and my panny DVD player..... even though there is no HD broad casts yet is there any way i can get a HD picture from another source...
    What settings have people set there tv sets to as well.ie colour!!!!!!!!!!!!!
    Please help!!!!!!!!!!!! :thumbsup:
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Sky+ is using a good quality scart lead (Sky set for RGB output). The DVD depends on which model you have and which connections it has.
    Easiest way to see some HD is to hook up a PC and watch some downloaded movie trailers, etc.
  3. twiglet
    twiglet
    Mar 2, 2005
    149
    Thanks for the reply.i only have the basic scart lead that the sky box came with ,would u recommend me getting a better quality one, if so where is the best place and what makes should i be looking at!!!!!!!!! :thumbsup: :thumbsup:
  4. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Yes, upgrade your scart. Perhaps aim for around £40 upwards, depending on your budget really. You can pay silly money, but the difference becomes negligible beyond a certain point, unless you are using a very big screen (or are extremely fussy!).
  5. Steve78
    Steve78
    Oct 30, 2005
    14
    Hi, I also got my LE32R41BD today and let me summarise:
    DVD via S-Video - awful picture! Too much contrast, blurred visuals
    Video via SCART - awful picture! Too much contrast, blurred visuals
    Xbox/PS2/GameCube via RGB SCART - awful picture! Too much contrast, blurred visuals
    I see a pattern here!
    The images I got on my old CRT were crystal clear and my cables are of a good to average standard but I expected far better than this.
    I'm sure I've set everything up correctly. I'm bitterly disappointed at the moment :(
    Can anyone offer any advice??
  6. smallmanongn
    smallmanongn
    Okay so a blurry picture might be more difficult to sort out but there are user options for colour etc,play with them and find a level you find works best for you,peoples choices are always going to be different.
  7. Steve78
    Steve78
    Oct 30, 2005
    14
    I still can't get it looking much better! I just tried my PS2 with PES 5 and it looked horrific! :( I tried 50/60hz and it still looks crap.
    The Xbox doesn't fair much better. Some fellow forumites on the rllmuk forum have validated that this TV is useless on RGB.
    Playing a DVD via S-Video isn't too bad but it's not even a quarter as good as my old CRT.
    I'm so disappointed I can't really put it in to words! I'll go back to tinkering with the settings again but after seeing how crap playing games look on this TV I'm close to packing it back up and sending it back.
  8. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Perfect pic from all sources. Svideo DVD excellent. Even the old VHS looks good on this set....
  9. Steve78
    Steve78
    Oct 30, 2005
    14
    How have you managed that?? Do you have über expensive leads or something?
  10. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    Everyone has varying levels of tolerance for picture quality so what one my find acceptable, another may find unacceptable.
  11. norealplan
    norealplan
    Mar 26, 2005
    5,142
    Backpacking around the world
    +733
    Is the issue of bad RGB/S video quality the same on every set, or is it just some people make a bigger deal of it than others. I was just about to buy this (using it mainly for 360 and comp screen along with occasional regualr tv viewing) however was also going to use my multi-region dvd player that only has rgb scart and s video. How bad does it look? I know eventually i will end up gettin a blu-ray player and use HDMI but I don't want to be annoyed till then.
  12. cpt1979
    cpt1979
    Mar 6, 2005
    1,440
    48
    Brighton
    +41
    I have has this LCD for 4 months now. It took about one month to settle in, and the picture has improved immensely.
    The best things come to those that wait!
  13. norealplan
    norealplan
    Mar 26, 2005
    5,142
    +733
    Think i'm gonna get one of these bad boys tomorrow! Cheers.
  14. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    No I don't believe in the expensive lead route. Mine are about a tenner each. In fact one was £4.99.
    I managed it I guess by not messing too much.
  15. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    I don't have any tolerance for lack of quality. If I buy something I expect it to work and do the job I bought it for. I can assure you that if there was the slightest sign of inferiority on my set of whatever make it would end up back at the shop. :D
