samsung le32r41bd pc game
Discussion in 'Samsung TVs Forum' started by scott1527, Oct 28, 2005.
Tags:
  1. scott1527
    scott1527
    having just unpacked my samsung and hooked it upto my pc via vga - vga cable i have noticed that using the same graphic settings as mycrt it seems to lower the details in game. is this the tv or could it be iproved with a dvi - dvi connector or scart - s-video.
    what im trying to say is whats best connection to use for tv - pc.
  2. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,485
    Essex
    +1,101
    ild say the best would be dvi to hdmi.....
    though depends if ur graphic card has dvi....
    and depends if you plan to use the hdmi connection with ....
    dvd player or sky etc.
  3. scott1527
    scott1527
    graphics has a dvi (radeon 9700 pro) dvi with 6 pins plus two at teh end (think thats digital and analogue compatible) i have a built in freeview box so hdmi sounds good. id only be using the comp occationally so even with a dvd recorder etc taking it out wouldnt be a prob.
    cheers
  4. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,485
    Essex
    +1,101
    yer you could just swap leads about when needed..
    or possibly ( if they do them yet ) a hdmi adaptor..
    you know like the 3 to 1 scart things they do..
    just push a button to change scart connection etc.
    if they aint out yet im sure someone will start to make them..
  5. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    I thought HDMI is protected so pc feeds cannot be used?
  6. hiphopapotamus
    hiphopapotamus
    Oct 15, 2005
    1,404
    48
    Aberdeen
    +68
    surely the protection is AVAILABLE but not mandatory on the connection... i think its only protected by people like sky hd and thats why everyone needs a protected hdmi port
  7. Yaka
    Yaka
    Dec 20, 2000
    1,811
    2
    63
    +147
    dont think this screen offers 1:1 pixel map over hdmi when connect to dvi port on a gfx card
  8. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    Does it offer 1:1 pixel mapping over VGA (D-Sub) so 1360x768 is not scaled to 1366x768?
