samsung le32r41bd or le32m61b
Discussion in 'Samsung TVs Forum' started by jpb82, Mar 17, 2006.
Tags:
  1. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    hi
    before today i had decided to get either the
    panasonic 32lxd60 or samsung le32m61b
    i have seen a hd demo of the lxd60 but i just cant find a
    le32m61b to demo it.
    on the way home from work a went into comet just in case they had the
    le32m61b on display and they didnt but what they did have was the
    le32r41bd showing some hd footage and wow it was fantastic and even better than the panasonic in my opinion. so i will probable go for a samsung but which one. if anybody has seen both the le32r41bd and
    le32m61b in action could you tell me which one you personally think produces the best picture and also is the most reliable.
    any help you could give me would be appreciated
    thanks
  2. mrm3
    mrm3
    Oct 29, 2004
    2,034
    48
    Cobham
    +95
    Think no one would argue the le31r41 over the le32m61. The latter is better.
    But it is more expensive and the d at the end means le31r41 has a digital tuner.
    I would pay the extra and get the le31m61 if I had to choose one.
  3. lexmeister2
    lexmeister2
    Nov 18, 2005
    149
    +3
    I don't know about the Panasonic, but there is absolutely no contest between the Samsung R41 and M61, so if you thought the R41 was better than the Panasonic, you'll be amazed by the M61 :thumbsup:
  4. jpb82
    jpb82
    Nov 22, 2005
    800
    Rugby
    +18
    the only problem is that if i choose the m61 over the r41
    i will not be able to demo the m61 before i buy it.
    do you think i should take the risk?
  5. Kendo76
    Kendo76
    Dec 19, 2005
    146
    Brentford
    +3
    I've got the 32M61 and have to say it's the best lcd I've ever seen. It's so much better than I thought it would be. Just make sure you buy good quality cables to get the most out of it.
  6. jobe
    jobe
    Jan 27, 2005
    40
    9
    Kendo.
    Others have stated the M61 can suffer from motion blur whlst gaming, and that Samsung LCD's are not very good at SD broadcasts, whats your one like?
    Jobe
