Samsung LE32R41BD & LE32R51BD Is there a difference?
Discussion in 'Samsung TVs Forum' started by Faust, Aug 29, 2005.
Tags:
  1. Faust
    Faust
    Dec 21, 2002
    3,156
    UK
    +638
    I have just been reading the What Video & Widescreen t.v. bench test report on the Samsung LE32R41BD LCD panel. The report gives this panel "Best Buy" status and a glowing report. Now I have noticed that Comet are selling this panel for £1099 which seems good value. However, Currys are also selling what on the face of it appears to be the same panel again for £1099. I say on the face of it because if you look at both panels the one in Currys has the black surround extending down into the speaker area in the shape of a V and it also carries a slightly different number i.e. Samsung LE32R51BD the surround on the 41 is straight all the way round. Both panels are HD Ready, integrated Freeview tuner etc. Does anyone know what if anything is the difference in these two LCD panels from Samsung? I'm simply curious.
  2. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Everyone here states that the only difference between the 51 and the 41 is cosmetic.
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,064
    2
    4
    137
    Airdrie, Scotland
    +964
    From other threads in these forums, I believe that the difference is purely cosmetic.
    Cheers,
    Martin.
  4. wush
    wush
    Aug 20, 2005
    47
    Which look does everyone prefer? I think the straight edge on the 41 is a lot more attractive.
    Will the 51 replace the 41 in retail or will they both co-exist?
  5. Faust
    Faust
    Dec 21, 2002
    3,156
    UK
    +638
    I prefer the straight edged one i.e. the 41 which I think is the latest spec. For anyone that has not read the review of this LCD in What Video and Widescreen TV, this is what was written in the conclusion section
    The ratings were as follows
    Picture *****
    Sound ****
    Features *****
    Ease of use ****
    Value *****
    Overall Verdict *****
  6. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,268
    East Yorkshire
    +313
    If it wasn't for the fact that my TV has developed a major picture processing fault after just one month I'd agree with that for the most part. The picture is superb (when it works!) but the sound is pretty ordinary erring a little bit on the tinny side and more deserving of *** than **** in my opinion. As for features, compared with what I've seen offered by other LCDs, the Samsung TV is fairly basic in terms of picture options etc so it would get **** for Features.
    Assuming I get a replacement that actually works for more than a month and doesn't have tearing I'll rate it ***** for value and overall too.
  7. Faust
    Faust
    Dec 21, 2002
    3,156
    UK
    +638
    I have spoken to Samsung CS today concerning the difference between the 41 and the 51. CS insist that the 51 is the newer of the two models, though not by much, and has more recent firmware installed as standard. I can only assume they are referring to the tearing issue. However, the CS rep either couldn't or wouldn't elaborated further.
