David Mackenzie
Mine has just arrived. I'll give you all some more info ASAP.
Have you tried both PAL & NTSC (50 & 60hz) material over HDMI ? Also was this 540P, 720P or 1080i? Any chance you can also try these via Component for me?
maddav said:Yeah I'm really unsure now, whether to wait the 3/4 weeks with Empire, or possibly look elsewhere, oh and my card won't get charged until it is despatched, assuming it does get despatched in the first place
maddav said:I'll phone them up now, and say that I'm prepared to wait, I've read the manual fully and the features look amazing it has all the connectors I want (plus a bit more good for futureproofing - HDMI), the initial feedback here seems good, overall I think it'll be worth it, though I will keep in constant contact with Empire, and I will relay what they say about stock availability
Now what can I do for 4 weeks with a brand new DVD player, Speaker System and no (decent) TV...
paulfoley said:Thanks Lyris
Basically then we can confirm the following works well so far :
VGA - 1360x768 1:1 mapping (Cheers Roost)
HDMI - 480P (60hz) 576P (50hz) *
* Or is your player converting all signals to PAL Friendly 50hz ?
Come on then guys we neen more test results, looking for :
720P & 1080i tests at both 50 & 60hz via HDMI & component ?
Mine isn't - everything is output native.* Or is your player converting all signals to PAL Friendly 50hz ?
Roost said:I've just taken some pics of the TV itself a couple with a madagascar hd trailer running and then 2 of the connections. The connections pics are a bit blurry, sorry about that but i was in a bit of a rush heh
Remember i haven't touched a single setting other than country and the clock so it will be very easy to get it looking better than this!!
There on there way to lyris over msn now so should be up soonish!
