Samsung LE32R41B terrible picture
Discussion in 'Samsung TVs Forum' started by mark pallister, Oct 23, 2005.
Tags:
  1. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi just bought a sammy le32r41b
    i am using a dennon 2900 dvd player connected to a yamaha dsp757 reciver via commponent leads witch is connected to the tv using commponent
    the picture is totally crap
    have tried using a different dvd player,no joy
    have tried every type of connection know to man,no joy
    tv picture via sky+ is great
    anyone??
  2. smallmanongn
    smallmanongn
    Is that in addition to this problem you are having?
    http://www.avforums.com/forums/showthread.php?t=256186
  3. mark pallister
    mark pallister
    Mar 1, 2005
    88
  4. mark pallister
    mark pallister
    Mar 1, 2005
    88
    come on there must be hundereds out there with this tv
    does every one else get good dvd pics?
    is my set faulty??
  5. Scoobiesnacks
    Scoobiesnacks
    Jan 1, 2004
    565
    Manchester
    +19
    There is a known fault on this model, do a search, its not that you're encountering is it?
  6. smallmanongn
    smallmanongn
    Have you tried just connecting the DVD to the LCD without looping through the amp,have you tried a straight RGB connection between the two,on my Sony DVD recorder the component otputs need to be turned on in the settings
  7. mark pallister
    mark pallister
    Mar 1, 2005
    88
    yea ive tried that using commponent and then svideo
    ive even tried a different player
    still the same
    if the set was faulty shuley the tv pic would be bad?
    but its good!!
  8. mark pallister
    mark pallister
    Mar 1, 2005
    88
    the question is,
    will i have to buy a dvd plyer that upscales to get a good pic???
  9. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    No, My old LG DVD gives an excellent quality picture on this set. You may have a bad set of connections within the set if the TV pic is ok, and you have checked all of your leads and connections.
  10. Jim Barry
    Jim Barry
    Dec 13, 2004
    82
    +32
    I bought one of these recently and sent it back straightaway because the picture was, as you say, totally crap. Not entirely sure what you mean by "picture via sky+ is great" but I quickly found that all external inputs were marred by a horrible sharpening filter that could not be disabled by turning the sharpness control down to zero. I had the LE32R41BD model and even the picture from the internal Freeview tuner was awful.
  11. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I had the same problem as SirSleepalot, non-defeatable and entirely excessive edge enhancement. I believe it varies among the firmware versions though.
  12. Jim Barry
    Jim Barry
    Dec 13, 2004
    82
    +32
    I had mine only 2-3 weeks ago (from DigiUK) so it would still appear to be a problem with the currently shipping version.
  13. mark pallister
    mark pallister
    Mar 1, 2005
    88
    to chriszzzz
    hi thanks for the reply ive tried connecting with svideo and commponent,just the same
    used the same leads to connect to my amp and get a great pic via sky
    just to recap
    connect denon dvd 2900 to tv crap pic
    connect sky+to tv using same leads and connection good pic
    have even tried a different dvdplayer no joy still crap pic
  14. mark pallister
    mark pallister
    Mar 1, 2005
    88
    to sirsleepalot
    my tv works fine when connected to sky+ its just when u fed it a dvd signal it goes all to cock
    was yours like that??
  15. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi all
    quick update
    checked tv this morning and fault appears to be getting worse,so i think it must be a fault with the tv
    will contact samsung today
    and post a update later
  16. Gonky
    Gonky
    Mar 19, 2005
    284
    +40
    Have you got progressive scan enabled on your DVD player?
  17. Jim Barry
    Jim Barry
    Dec 13, 2004
    82
    +32
    No, mine was consistently bad with all sources. Let us know how you get on.
  18. Gonky
    Gonky
    Mar 19, 2005
    284
    +40
  19. Chris White
    Chris White
    get the update from sammy. My 32 bdx was a little doged on rgb and s vid, when update it sorted it out. Im not promising its the software but its a good start. Sammy should get cd and lead to you next day!
    Chris.
  20. mark pallister
    mark pallister
    Mar 1, 2005
    88
    late update
    phoned samsung today and tvs getting picked up on wedensday,it will be away for 10 days
    no replacement in the mean time
    i only bought this set on friday
    samsung say that they dont send out engineers for this type of set,
  21. Gonky
    Gonky
    Mar 19, 2005
    284
    +40
  22. smallmanongn
    smallmanongn
    Your first port of call should be where you got it from,you have 28 days from date of purchase for the place you get it from to put any problems right or exchange the set,after 28 days then you need to contact Samsung direct.
  23. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi yes ive got progressive scan enabled it makes no difference
    smallmanongn,
    if thats the case shoulnt the samsung rep have addvised me of that??
    actually the set is starting to get worse ,its starting to do it in tv mode as well now
  24. smallmanongn
    smallmanongn
    Well when I had mine from Comet they said within 28 days if it delevoped a fault within that time they would send someone to look at it.
    When it did go wrong 2 days later someone came to look at it,declared it a right off and I took it back to the shop and got a refund,I could have had replacement but at the time they didn't have any more in stock.
    I also checked with Currys and they said the same,the only difference was I would need to take the set back to the shop and they would test it there.
    If its less than 28 days old contact the people you got it from,they have to sort it out.
  25. mark pallister
    mark pallister
    Mar 1, 2005
    88
    cheers smallmanongn
    looks like thats what im going to have to do tomorrow
    out of interest what did u end up getting to replace the sammy??
  26. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Thats odd, Ive had an engineer out to look at my set, (40" model ) and another visit tomorrow.
    Not sure why they told you that
  27. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi lurch the tv was only bought on friday last
    contacted samsung on monday
    they said they would send someone to pick it up on wed(today)
    when they came they said it was not worth them takeing it away,due to it being so new it would be replaced by the supplier,
    rang them and they contermed this
    what was the proplem with your set??
