Samsung LE32R41B Possibly faulty
Discussion in 'Samsung TVs Forum' started by yoshi-1, Sep 18, 2005.
Tags:
  1. yoshi-1
    yoshi-1
    Hi All,
    I recently recieved my new Samsung LE32R41B from 24 electric. I plugged it in this afternoon and all seemed to be going ok. However now when i switch it on there is no picture whatsoever, just the balck sceen as though the set was off.
    I see the red light flash and there is a slight audible noise and then the red light goes out. Acording to the manual this is the correct set of events for the screen to be on.
    However when i press the menu button or try to do anything i get nothing at all on the screen. I do see the red light flash on the screen power button so it is recieving the signals from the handset.
    I'm tempted to think the image is goosed, there doesnt seem to be any sound either for that matter. Hope i'm wrong as its been 6/7 weeks for it to arrive.
    any help appreciated.
    cheers
  2. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,428
    East Yorkshire
    +313
    Can you see the menu/access it by pressing the Menu button on the remote?
    If you can't then it sounds like your TV has a very serious fault unfortunately and you'll have no choice but to ring your supplier and arrange for them to deliver a new one.
  3. yoshi-1
    yoshi-1
    Hi Darren,
    Thanks for the reply. As i mentioned in my previouse messaged........
    'However when i press the menu button or try to do anything i get nothing at all on the screen'
    Unfortunatly i'm of the opinion that you are correct about it being badly faulty. Regardless of any settings etc the menu should come up. In fact nothing comes up no matter what I do. I'll get in touch with 24electric in the morning.
  4. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,796
    Bexhill on Sea
    +239
    Don't want to appear to be "hi-jacking" your thread, but if I started a new one with the same title things would get a little confusing???
    Had my television for just over a week now and very pleased with it apart from one thing.....
    I was watching a DVD the other evening, connected via component for prog scan, when a row of white horizontal lines appeared across the screen.
    They weren't the same as the lines seen in the "tearing" thread, they were solid white ones that were static, and lasted about a second at most.
    Didn't think too much about it at the time, put it down to a "glitch" in the disc. Unfortunately these same lines appeared yesterday whilst watching another DVD. This time they stayed on the screen for about 10-15 seconds, giving me enough time to actually switch the TV off and on again to see if that cleared them....it didn't.
    They stayed on the screen another few seconds after switching on and then disappeared again.
    As I say, these lines were stationary, no movement at all, and filled up the middle "third" of the screen.
    Hasn't happened while watching either analogue or digital inputs, just the twice now whilst watching DVD's.
    Something to do with the progressive scan?
    :confused: :confused: :confused: :confused:
  5. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    To me this sounds like it's been left in the PC mode without anything being sent to it. This is the one completely stupid design decision Samsung made with the set.
    If you've got it in PC mode with no input, you'll get a blank screen when you turn it on, as it immediately kicks into its "power saving" mode.
    If you hit the input button, or TV one, it should show everything again... if not, it's faulty. :(
  6. mickymcd
    mickymcd
    Sep 5, 2005
    929
    boro
    +38
    What warranty does samsung give with these sets one is on my shortlist when i see a decent price thanks. :thumbsup:
  7. miketrim
    miketrim
    Jan 11, 2005
    688
    +8
    Looks like mine is faulty too. Got a problem with Tuning at higher of the tuning frequencies
  8. miketrim
    miketrim
    Jan 11, 2005
    688
    +8
    Did you phone 24e? If so what did they say
