digitalwolf said:I have a brand new le26r41BDX.
How can I test it out on HD to see if I have the tearing problem?
I have access to a HD satellite receiver that will connect up to TV via component so are there any channels on Astra1/Hotbird that transmit will cause tearing?
Does the satellite receiver output a 50Hz picture signal or 60Hz since the tearing issue is only visible on 720p - 60Hz sources.
