samsung le32r41 Fault
darrensen
I have the above screen and when i turn it on i get sound but no pic.
Is this a common fault?
Darren
Woodywizz
I'm presuming you've checked all connections are secure.
Sounds like a backlight failure - contact Samsung direct and get them to sort it out for you. They should offer you a replacement panel if your still under warranty.
Best of luck.
darrensen
Yeah all connections are in. I've tried different scart ports and the vga port.
When i turn the tv on i get the input display in the top left (ie scart) but when that disappears all i get is sound. If i'm quick whilst that scart text is in the top left i can bring the menu up, but then that goes as well.
Are you sure it's a backlight fault?
I got the unit from Comet and they are sending someone out to take a look. I will let you know what they say.
cheers
Darren
Similar threads
