Samsung LE32R41 and LE32R31 differences?
Discussion in 'LCD & LED LCD TVs' started by ciarancummins, Aug 17, 2005.
  1. ciarancummins
    ciarancummins
    Mar 9, 2005
    82
    Dublin
    I've been researching which 32" LCD to buy, and the Samsung LE32RXX model has come out on top due to looks/features/price. I am prob going to buy from Dabs, and they have loads of R31B 's at the moment, which are £50 cheaper than the R41B. I have seen the
    R41 up close and read all the reviews here, but there does seem to be a bit of difference between the 2. Samsung site is poor for specs for these models, as they still have the LE32A41 details there :( Tuners are not that important since I will be connecting it to a Digi-TV source. If anyone has links to proper samsung spec site please reply. Also, tearing issues with these models worry me, but maybe the R31 is not effected as I have not seen it mentioned in the tearing survey.
    Some differences I found:
    R41 R31
    Contrast Ratio: 3000:1 - 800:1 ( Can this be right?? )
    PVA tech (?) : No? - Yes ( Might be with R41, not sure )
    Any insight into this appreciated.
    Also, if you would recommend a different 32 LCD for £800-£850 please tell me
    Cheers,
    Ciaran
  2. next010
    next010
    May 29, 2005
    9,468
    +1,840
    Discussed in this thread but never got a definite answer but from looking at the specs myself the brightness, contrast and viewing angle are all slightly inferior to the LE32R41B as for the 3000:1 ratio they use what’s called a dynamic measurement there but I do not know if they are using the same means of measuring for the LE32R31S (Dabs cut off the S for some reason but that’s its proper name).
    That’s all I know looks to be the same generation panel maybe a slightly lower grade one so that’s why its cheaper but I'm just guessing...
  3. ciarancummins
    ciarancummins
    Mar 9, 2005
    82
    Dublin
    Thanks for the reply, just bought the LE32R41B yesterday from Dabs, but now I want
    a LE-32M61B http://www.samsung.de/webdownloads/pictures/le32+40m61b.jpg
    btw, the R41 has 500cdm's and the R31S has only 400cdm's, so the 41 is prob a better buy
    for £50 quid more just for the better quality panel.
    Oh well. Maybe I will flog this one in a couple of months and get the newer one!
    Cheers,
    Ciaran
