Samsung LE32B450C4 - PC Sound help
DeSolat3
Hey all, ive just bought the Samsung LE32B450C4 to use for my pc and spare xbox in the back room and its all setup and working.
I just dont know how to get sound for my pc, its connected by vga cable.
My sound is coming from my sound card in the pc by a headphone jack, http://chadt4.files.wordpress.com/2009/06/audio_extension_cable1.jpg
Is there a socket at the back of this tv so i can plug it into? can i put it into the PC/DVI audio input socket as i dont wonna test it just incase i break it :(
Curly99
Next to the VGA input is a 3.5mm jack input, I think it's labelled PC audio in or similar, your manual should have a diagram or picture of the rear inputs, use this for sound, the cable you need would be a 3.5mm - 3.5mm.
DeSolat3
Ive tried that and ive tried using a 3.5mm jack with the white and red ends for audio but none gives me sound...
P.S Scrap that, my sound gotta be higher on my pc settings on a tv lol. all works fine now thanks :)
