Samsung LE32A656A
Discussion in 'Samsung TVs Forum' started by g style, Jan 29, 2009.
Tags:
  1. g style
    g style
    Jan 13, 2009
    7
    Hi all i have the above tv and its now starting to get to me abit due to the fact that the bloody thing keeps setting its self to dynamic (when you have turned it off and on agian and after a small amount of time when your watching it) when i have turned to standard or movie. Is there anyway of being able to set the settings so that they stay the way you want i have also tryed some of the settings that peeps have posted up and have yet to find one that i think makes the tv look better then again all the settings that i have seen are for the 37" upwards non for the 32". Can anyone help.
    Thanks.
  2. EarthRod
    EarthRod
    Jul 15, 2008
    17,787
    England
    +7,887
    From what you're saying the TV is in 'Store Demo' mode, it should be in 'Home Use' mode.
    If you look at the manual under the 'Plug & Play' feature you will see how to change the setting to 'Home Use' mode.
    Alan
  3. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    To change between "Shop" and "Home" modes press menu+Volume on the TV not the remote for 5 - 10 seconds, the TV will blank and on return the OSD will display "Dynamic" change the settings and the TV should now save them. If you have any problems changing it this way, switch the TV in to Analogue mode, TV/DTV button on the remote and through the TV menu select "plug and play" and change it from there.
    Curly
  4. g style
    g style
    Jan 13, 2009
    7
    Thanks Alan will have a look at that in the morning when i get in.
  5. g style
    g style
    Jan 13, 2009
    7
    Thanks for the reply curly.
