I've been on the lookout for a moderately priced 32" 1080p HDTV for a while now, and the above model has taken my fancy.
I saw it here, and the specs appear to be quite good. The only problem is besides the two line review on that page, I haven't been able to find anything else on the product
What I want it for primarily is playing the PS3, as I've noticed the difference between 1080p and 720p can be quite large at times, and watching the occasional Blu-Ray movie too. I know some people say that you shouldn't bother with 1080p except for 37" or upwards, but I'm used to a large resolution on a small screen. I'm using a 1440x900 resolution on my laptop right now!
The thing is, I still only have an ordinary analogue TV signal. Standard terrestrial stations through an aeriel. Will a TV of this resolution make them look awful? Well, much worse than they already are
At the moment I'm using an old SD widescreen TV, a Philips one. I see that the TV has an inbuilt digital tuner however, does that mean I'll get digital freeview stations without any extra equipment?
Or if you think I should go with a different brand/model please make suggestions. I will say that it has to be 32" though, I sit about 3 feet from the screen and don't have room for anything bigger at the moment!
Thanks in advance!
Thanks in advance!
