Please, i cant find this information any where.
I found one website that stated wall mountable; but it doesnt state if its vesa or what the numer x number is for this.
I want to buy the wall mount and attach this to the wall tomorrow so its important i have the information. I'd appreciate if someone could post this asap.
Many Thanks.
Hi..
I'm not to sure to be honest. I looked in the instruction manual and i've seen a bit on wall mounting but it doesnt state what the sizes are or if its vesa compatable.
I'll have a nosey around some electrical shops today to try and find out.
Thanks anyway.
This TV has a VESA 200mm x 200mm hole pattern. Any VESA bracket which goes to 200 VESA will fit, also any universal bracket for 32" will fit. We have various whether you require flat, tilt or articulated;
Thank you very much for the reply Graham. Sadly i managed to get hold of a wall mount last weekend otherwise i would of taken you up on your wall mounts. Next tv i get i'll be sure to speak to you.
Thanks.
