Samsung LE32A41B or LE32A41BX?
Discussion in 'LCD & LED LCD TVs' started by si_phillips, May 1, 2005.
  1. si_phillips
    si_phillips
    Hi All,
    I have noticed that there are two models of the Samsung LE32A41B, namely one with an "X" and one without...Does anyone know what the difference is between these two sets?
    After trawling through countless spec sheets, I have pretty much decided upon this 32" for around £1k. Thoughts?
    As far as I know, this set will be compatible with the upcoming Sky HD broadcasts? is this correct?
    Thanks for your help!
    Si
  2. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Samsung LE32A41B is all that is listed on the UK Samsung site, believe there is no difference between the B & BX, it is HDTV ready as it has DVI (HDCP), been seriously considering this one myself, another thread gave a very detailed review a few months ago, seen it in the flesh to, very smart.
