Samsung LE3241DX - Help on freeview ???
Discussion in 'Samsung TVs Forum' started by armando1065, Oct 14, 2005.
Tags:
  1. armando1065
    armando1065
    Sep 16, 2005
    57
    I purchased the above telly from Waratah - excellent service by the way - and did the plug and play method and it didnt tune in any of the Freeview channels ?
    Have i hooked it up wrong - I have a SKY box plugged into the RGB Scart and the normal aerial into the back of the telly and that is it.
    Have i dont something wrong - i know ive got all the Sky channels anyway BUT if the kids want to watch their cbeebies whilst im watching footy in the other room then id be okay.
    Am i being foolish or something ???
  2. Chris White
    Chris White
    ive got the same set but cant get freeview where i am.
    i think that the digital tv channels dont get picked up when plug and play occurs.
    I think you need to go in to the DTV menu and select search for channels. Its easy to do just look in the DTV section.
    Chris.
  3. armando1065
    armando1065
    Sep 16, 2005
    57
    Thanks Chris
    I'll give that a go tonite - havent had any time to play with the telly yet as i work away midweek.
  4. Chris White
    Chris White
    no probs.
    press DTV button and then when in there presss DTV Menu button and its easy to spot! I think its somthing like "Search for Channles!"
    Best of luck!
    Chris. :hiya:
