B
bonc
Lyris said:To be honest I have to look at this from two points of view, the first one is that if you're happy with it then good on you.
The other one though relates to the eye rollingsmilie thing. Are you suggesting that it's OK to spend into the hundreds on a TV and then complain when it has faults like this? If so... talk about lowering the bar
And are you suggesting there is a perfect LCD screen out there that has no faults whatsoever - do tell!!????
It is the nature of the beast, almost all AV equipment will have some nuscance or another. Tearing, we could not look past, but green flashes alot of us are putting up with it as it is not a huge distraction (hence the low key posts on this topic)
when the tearing issue was in full swing, I contemplated swapping this LCD for another - but for the money, features, value & quality - nothing came close - and in my eyes still dosent!
A green flash every 2hrs (if that) on freeview is not enough for me to seek a refund!
However, being the ambassodor for all things Samsung Lyris, be my guest - give Samsung a ring, raise the bar - demand that green flash firmware upgrade for us!!!
