Samsung LE32 R74 & VGA
Discussion in 'Samsung TVs Forum' started by fcz, Feb 5, 2009.
Tags:
  1. fcz
    fcz
    Sep 23, 2006
    1,735
    +195
    i have my 360 connected to my r74 using vga. have had for couple of years now. but just recently i've noticed when i go to the pc setting to play the 360 i have about a one inch black strip on the right hand side of the screen. i don't have a line on the left or above/below. i have went through all the options in the tv menu but can't find one to get rid of the black strip or move the picture right to even up the screen. i don't seem to be losing anything on the left either. when i play cod4 or fallout3 i'm not missing any of the hud etc.
    its not a massive problem but its starting to annoy me a bit now, even though it doesn't affect my gaming. the hdmi, ext1 and ext2 settings don't have this problem, its just the vga setting?
    any suggestions?
    thanks
  2. oldnewbie
    oldnewbie
    Feb 13, 2006
    1,076
    63
    +164
    Press menu then go to setup then pc then auto adjust or position :thumbsup:
  3. fcz
    fcz
    Sep 23, 2006
    1,735
    +195
    thanks mate!! will give it a go as soon as i can get playhouse disney turned off without being squeeled at!!:rolleyes:
