Samsung LE26R74BDX - Sound issues
Discussion in 'Samsung TVs Forum' started by dobbadobbs, Apr 23, 2007.
Tags:
  1. dobbadobbs
    dobbadobbs
    May 16, 2006
    673
    +18
    Just noticed earlier i had a funny buzzing fuzzy sound from the speakers when there is noise/talking on my tv - that is until i switch off the tv, then all is normal....
    Should i be looking to send my tv back for repair? Is this a known issue?
    Many thanks, Craig
  2. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Having the R73 for 5 months before I exchanged it, for an unrelated matter, I had the same issue a couple of times. Turning it off and back on fixed it. Its an intermitten problem, you couldn't replicate it if you tried, and the fix is easy, turning on and off, so repair is useless.
  3. Neil2007
    Neil2007
    If the volume is at a reasonable level and the equalization controls are set to the mid positions and the sound is still not correct the TV may need to have a service call
