Samsung LE26R74 fault?
SlinkDaddy
Hi i've just had Sky+ put into this set and thinks its faulty. When a pic which is mostly dark with a little colour in it shows on the tv it flickers/flashes lighter then darker alomost like the contrast is going from max to min and back again. It has been doing this since i got the set but l had put it down to the poor signal from the wireless sender i was using. Anyone else had this fault? Is it common? I think i'll prob have to take it back and swap it at my store.
Mmm now i've put the wall bracket up i could get a 32"!
Intya
Try turning Dynamic Contrast off. If that doesn't work, then yeah, I'd have someone look at it :confused:
SlinkDaddy
Dynamic is off mate. First thing i did when i got it plugged in.
JPebmm
I think you are confusing the "Dynamic" picture settings with Dynamic contrast.
If you switch to the "Movie" picture settings, this will turn off the Dynamic contrast.
SlinkDaddy
Cheers for that peeps! it worked, i guess its my fault for never looking in the instructions.:thumbsup:
