Samsung LE26R73BD question
Discussion in 'Samsung TVs Forum' started by nessuno, Apr 29, 2007.
Tags:
  1. nessuno
    nessuno
    I recently purchased a Samsung LE26R73BD which on balance I quite like apart from the Freeview rendering. (As an aside, why does Freeview look odd on an LCD or is it just my Samsung? :) )
    I wanted to know what the difference is between the LE26R73BD and the LE26R74BD? I notice the later got a good review in "What Hi-Fi" and the R73 isn't mentioned - neither are on the official Samsung website as it would appear they only do the 27" variety now.
    Any comments/pointers would be appreciated! Many thanks.
  2. nessuno
    nessuno
    My apologies after some trawling on the forum I found the answer - the difference is purely cosmetic between the R73 and R74.
    My question about Freeview looking odd sill stands though!
  3. oldnewbie
    oldnewbie
    Feb 13, 2006
    1,076
    63
    +164
    The only difference between the two is the r73 has a blue strip at the bottom and the r74 has a silver one, that's it.
  4. oldnewbie
    oldnewbie
    Feb 13, 2006
    1,076
    63
    +164
    You beat me to it and answered your own question lol, the freeview rendering can look a little better if you tweak the setting a little but I think its par for the course with all lcd's I'm afraid ( or atleast the ones I've tried )
