Samsung le26r51bdx remote problem
Discussion in 'Samsung TVs Forum' started by rickmoz, Oct 17, 2005.
Tags:
  1. rickmoz
    rickmoz
    Sep 4, 2005
    664
    5
    Barnsley
    +283
    Got this TV over one month and its ace :) ,but just switched the set on and none of the number keys work on the remote in fact all the keys seem dead apart from the mute and volume keys. Have changed the batteries and have cut the power to the tv and none of this works. I have not dropped this remote but i can not get it to work but when this morning it was fine.
    NEEP HELP is there something else i could try or has the unit just died on me.
    thanks rick
  2. wooky42
    wooky42
    Sep 7, 2005
    12
    Barnstaple
    Isn't there a reset button under the flap at the bottom of the remote?
    It says in the manual if the remote stops working to depress it for 2-3 seconds.
    Wooky
