Samsung LE26R41BDX + XBox. Best connection type?
Discussion in 'Xbox Forums' started by Shook, Oct 5, 2005.
  1. Shook
    Shook
    Sep 27, 2005
    27
    Ok so I'm completely confused about SCART, RGB 'Advanced' SCART, Component, S-Video and HD.
    I just want to know this... Which cable should I buy to get the best picture from my XBox?
    And can I view my XBox games in HDTV on my Samsung?
    I'm very confused.
    s
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    go for the official MS advanced HD pack (think thats what its called) basically the official MS component cable + breakout box. some games will output HD signal from the xbox but your xbox must be a NTSC console or a modded (soft or hard) PAL xbox with the video system output set to NTSC.
  3. Steven Jackson
    Steven Jackson
    Sep 25, 2005
    134
    Lincoln
    +3
    One more time, please, Kopite4Ever. Slowly....
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    ok i will try :devil:
    some game Dev's will code/programme their game to output at High definition Resolutions, these being 1280x720 (720p, p being a progressive signal) & 1920x1080i (1080i, i being an interlaced signal)
    microsolf allowed the NTSC machines to output these Resolutions to your display (if capable) but chose to take this function out of the PAL (european) machines as it was probably deemed so due to the fact HDTV wasnt really here at all during the Launch of the xbox.
    now natually as you can see if you have a NTSC xbox you can makeuse of this. you do need a Component HD pack shown here . you will not be able to obtain HD outputs without a component connection with the official M$ one being the best by far. now your asking most of us dont own a NTSC console, so whats next. you can either Hard mod or soft mod your PAL console. a hard mad is just that a physical chip installed inside the machine. this allows all kinds of programs to be run on the versitile machine including something called the Enigma Video Switcher. this allows you to change your Video output from PAL to NTSC hence allowing these HD outputs. this also lets you choose 480p as well which produces a better picture than the PAL's 576i output. there are concenquences of having a mod chip installed i shall let you research that. now you can do what i did, Soft mod the xbox. this basically tricks the xbox into running the enigma video switcher through an exploit in certain games, mainly the original splinter cell. you then do this and allow the HD outputs in the MS dashboard.
    From here games that do 720p like soul calibre will run at this HD res and will look like 'sex on legs' on your display
    hope that helps im not the best with words but ask more if you need it :hiya:
  5. Sami
    Sami
    Jan 15, 2004
    2,173
    Forest Hill, London
    +84
    SO do you still get a picture out of the Xbox using a component cable if the box isn't soft modded?
  6. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    correct, just its 480i and not much better than RGB scart
