Samsung LE26R41BDX issue - please help :(
Discussion in 'Samsung TVs Forum' started by hannay, Oct 26, 2005.
Tags:
  1. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    I bought this TV back in late august, and mainly am happy with it. However, after advise I purchased a component cable for my chipped xbox. I play Pro Evo 5, and also have played Fifa 06 and I get the same problem on both.
    The problem is this:
    9/10 times the picture is fine, then after a screen switch in game (ie a goal kick, free kick etc) the green on the grass goes much lighter, then after another free kick etc it goes back. it's becoming really annoying now. Have I set something up wrong, or is my TV just ****?
  2. Chris White
    Chris White
    have you looked a automatic brightness sensor?
    Silly q but make sure its turned off
  3. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    lol, i have no idea if i have one of those, and if so, how i would turn it off :D
  4. Chris White
    Chris White
    ive got 32" and its got one.
    Press the menu button, then go to picture and on the right where they are diff things listed. I thinks its called Auto bright or auto contrast or somthink. just turn it off and see if it works. Not promising
    thanks
    Chris. :hiya:
  5. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    sound promising though - cheers chris
  6. Chris White
    Chris White
    no probs, best o luck
  7. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    another question - i'm having sky+ installed on friday - can i get an RGB cable for it? and which is best one? ( iassume RGB is scart 1 only)
  8. Chris White
    Chris White
    dont know much about sky mate! sorry
