Samsung LE26R41B Screen Problem
Discussion in 'Samsung TVs Forum' started by skdcfc, Oct 18, 2005.
Tags:
  1. skdcfc
    skdcfc
    Oct 18, 2005
    57
    Derby
    I brought a Samsung LE26R41B 3 weeks ago and it has been great, no problems what so over.
    However over the last two days the screen keeps going funny and getting covered in bright pink and green little dots. If i turn it off and then on again the screen is ok for while before loads of the little pink and green dots apear again.
    What can i do about it?
    Cheers.
  2. Evil_Homer
    Evil_Homer
    Oct 17, 2005
    144
    19
    Deal
    Only 3 weeks old, take it back mate :)
  3. mister meaner
    mister meaner
    I have seen this on a Samsung in a local Currys store. I fugured it had been dropped as it was fine a few weeks before. Does it seem to choose one particular colour in an image that it then always shows in pink no matter where it is on screen?
    Now you suggest a similar problem with yours (which i'm sure you won't have dropped) sounds like its a fault. I'd contact the shop straight away and tell them its faulty.
    I wonder if its Firmware related???
  4. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,483
    East Yorkshire
    +324
    It sounds like a hardware fault. I'd take it back and get a replacement.
  5. garciag5
    garciag5
    Jun 16, 2005
    Ireland, West Coast
    +5
    Sounds like the same problem as with our sets Doc. Definately exchange it.
    Funny you say three weeks - the exact same thing happened to mine after "three weeks".
    According to Samsung's subcontractors that are carrying out the repair .on my set, it is due to a faulty Power Supply Board (PSB), but I am not sure how accurate that is. Funnily, they couldn't find a fault with my TV at all in the repair center - had to send them the photos, and based on these they diagnosed a faulty PSB...doens't really instill much confidence in me that my set will run trouble free when I get it back. :thumbsdow
  6. garyf
    garyf
    Oct 3, 2005
    32
    I've got a similar problem. My LE26R41B is only 6 weeks old. In the past 2 days green dots have started appearing, almost like a haze. It's especially noticeable on th eblack borders, so much so that they are almost entirely green, and when changing channels, the screen is mostly green instead of black. I am connected via RF for my analogue cable tv, scart for video and RCA video jack for DVD (DVD only has 1 output!). It happens on all 3 inputs.
    I've attached a picture taken with the screen in 4:3 format to highlight the problem. Can anybody give some advice?
  7. garyf
    garyf
    Oct 3, 2005
    32
    OK update: Engineer has just left with the tv under his arm. He says it is a problem with the panel, quite common on these sets. He thinks Samsung have come up with an improved panel and it is that that he will fit.
  8. garyf
    garyf
    Oct 3, 2005
    32
    So, engineer above quoted 1 week for it to be fixed. Called Visual FX yesterday for update. "it's in the workshop undergoing troubleshooting, expect 10 - 14 days for a fix". I asked why it should take so long when the engineer who came to my house knew the problem and knew what was needed? Person I spoke with hid behind th e' samsung insist we do a thorough check' argument. Oh well, if they are true to their word I should get it back fixed as good as new.
