I
ilicklcdscreens
I am considering purhasing the Samsung LE26R41B LCD screen and it will be my first LCD purchase. I have a few questions that you can hopefully help me with.
Would you rate the LE26R41B? I like the size and the features, also the contrast ratio looks higher than most of its competitors. What's the availability like on this model? Everywhere I try, it's out of stock!
What wall mount would you suggest purchasing? I've had a good look and have found this one: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14968&item=5787199351&rd=1 . Looks like a decent price and it supports VESA 200x200mm, the correct specification AFAIK.
Any suggestions/comments welcome
-- As an eBay Associate, AVForums earns from qualifying purchases --
