Samsung LE26R41B - Any alternatives???
B
Burgess99
I am on the look out for a 26" LCD, the Samsung LE26R41B is the best I have come across, I believe it was used in the testing of the Xbox 360. Can anyone recommend an alternative 26" for £600 or am I on the righpath???
you have the toshiba l56 and a sharp in your price range... check out pricerunner.co.uk and then filter it in the lcd section and itll show you everything in your price range...
but i mean, if you want an xbox 360, the samsung is a safe bet... nothing wrong with it at all
B
Burgess99
Samsung it is then, 2 months of uncertainty, many thanks
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
