Samsung LE23R8 as a PC Monitor
Discussion in 'Samsung TVs Forum' started by DBR9, Sep 22, 2007.
Tags:
  1. DBR9
    DBR9
    Hi, Can anyone help me to set up my Samsung LE23R8 as a PC Monitor, as i am having trouble with the setup. I am connecting the TV to a laptop using a SVGA Monitor Cable and an Audio Splitter but all i get when i change to the PC Channel, is a "Mode Not Supported" Message
    Can Anyone give any tips or guides?
  2. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Make sure you're using a resolution that the TV accepts via VGA.
    A list is located in the manual. You should refer to that and make sure the laptop is set to a correct resolution.
