Does anyone here have this model or know if it is good? - I can't find any reviews on it.
I realise it has limited connection compared to the bigger sizes, and i know that the xbox 360 is using component, but is it likely that HD-DVD players and the ps3 will have component cables?
Also, do you know if it has the tearing problems its bigger brothers the 26 and 32 had?
Batch
Batch
