Did you read my post GStev? For me HDMI 3 only worked ok with 570p input, all modes above that; 720p 1080i 1080p were giving various troubles.
Hello everyone,
It has been a while since my last post, I have a question, which I believe I already know the answer to, but need to ask.
I have had my F86 for over a year now and only just realised it has an optical output and my question is about that output.
Can the F86 relay sound of other devices, like a PS3 connected via HDMI through its optical output to an AV Unit/All-in-one Surround Sound unit?
I do not think it has that ability but would rather get an answer from someone that knows more about TV's
Hello everyone,
Hi All,
I've had my Samsung 40LEF86 for over a year now and have recently been experiencing a problem with the remote control.
I can turn the TV on from standby with it but then almost straight away I can't operate any other functions from the remote with it. The red LED remote light flashes as I turn the TV on - can't remember if it did that before.
I have tried tuning my Sky HD remote into the TV which seems to work as again I can turn the TV on with it but almost straight-away I can't operate any other functions e.g. volume.
I say almost straight away in both cases as if I'm quick I can change source, volume etc but then in both remote cases it fails to do anything else and I have to press the buttons on the TV.
I have changed the batteries in the remote and pressed the reset button but no joy.
I can't say for sure but I'm this started to occur around the time I had my Sky box upgraded to SkyHD. I've read about possible IR interference but no specific cases between SkyHD and Samsung TVs.
Has anyone else had this problem, can you suggest anything I could try? It's very frustrating!Thanks.
I had this issue a couple of months back, after 13 months of ownership.. but thankfully bought through JL so getting someone out was simple. They came, they didn't see as it was so hit and miss when it happened - DVD, Cable and or SD, so wasn't too stunned when they said they would have to take it away. So away ot went for 2 weeks only to be returned with NFF (no fault found) - They did say that they reseated anything and everything and couldn't see any issues, no biggy there... but since it's little trip all has been perfect again.
If you are still covered my advice get someone out before upgrading the F/W, having worked in IT and know a little about F/W I can say the latest isn't always the greatest.
All that said have to say really very pleased with the set, had no issues (other than this) and the picture is stunning as ever.
Hope you get it sorted and start enjoying again.
