Ok, I believe I have tried everything now. A separate problem I was first having of the monitor and tv not being picked up properly when I used a dvi splitter I will sort out after my main concern is the tv.
Atm I can only get [email protected] to display on the screen at most. I am using a 7600GS 512 Nvidia AGP gfx card which should be able to output upto [email protected] Using power strip I have managed to get something to show but it is not consistent and only works if I was on a resolution that worked previously and then switch to a higher res using some of the timings that moninfo picks up (which btw are different to the ones in the manual which I dont seem to be able to get).
So how do I get my tv on my comp at 1920??? After a reboot with tv connected windows picks up the resolutions that the tv can do as max of 1920x1080 and 4 different refresh rates 24-60, tried them all and get mode not supported on the tv. Any ideas?
