Samsung LE 26 R7 locked on channel
Discussion in 'Samsung TVs Forum' started by musttryharder, Feb 5, 2009.
Tags:
  1. musttryharder
    musttryharder
    Feb 5, 2009
    2
    I was doing a channel earch from the menu and got called away, so stopped before completion. When I restarted I cant move off channel 82. Back on analogue everything is fine but digital is locked. I can't access the dig. menu to try and retune. The banner and channel number does not time out either...................any ideas ??????
    :hiya:
  2. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    The Service Menu can be reached from Standby by pressing...
    Info-Menu-Mute-On
    there should be a reset option there for you to try. (Don't alter anything else!)
  3. musttryharder
    musttryharder
    Feb 5, 2009
    2
    Thank you very much. It worked !! I just followed your instructions and everything is now working, thank you again.
    :thumbsup:
  4. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    Well done. :smashin:
