samsung lcd wall mount help
Discussion in 'Home Cinema Buying & Building' started by seka1980, Jul 6, 2005.
  1. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    probably a realy stipid question but i need to get a wall mount for a samsung LE32A41B i know its VESA 100*200 , ive seen one on the maplin web site thats VESA 200 x 100 compliant would this work?
    if not where is the best place to get 1 quick?
  2. SteveW70
    SteveW70
    Seka,
    Which one on the Maplin site ?
    Any chance of a link so I can try to help.
  3. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
  4. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    Personally Id say use a VESA 200x200 mount, do you really want to be sticking something that expensive on the wall using 4 screws???
  5. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    im abit confused now
    would a 200 200 fit?
  6. SteveW70
    SteveW70
    Seka measure the distance Vertically and Horizontally between the fixing holes on the back of the screen and come back to me :smashin:
