Samsung LCD Tv Problem
golden007
hi
if some1 knows the solution for this problem kindly reply ASAP......
xyzbird
I think those more knowledgeable will want to know if this problem is still there on a normal TV received picture because it looks like you have something externally connected which might be the culprit.
xyzbird
You could try a full factory reset from the TV menu and if the fault is still there then you will have to call a qualified repairer. Samsung are pretty hopeless to communicate with and will probably still involve a local repairer.
