samsung lcd no signal on vga source when xbox connected
Discussion in 'Xbox Forums' started by bonannogiovanni, Dec 25, 2006.
  1. bonannogiovanni
    bonannogiovanni
    Dec 25, 2006
    19
    Hi, I have a samsung lcd tv set, and I'm trying to use it as the high def output for xbox gaming. So I connected the console through a component-to-vga converter to the tv, set the source as PC and turned it all on. But all I got was a black screen with a "not supported mode" on it. With my old lcd TV, it all worked fine. I know I can use the component output directly, but I'd like to try VGA because they say it has less jaggies. So anybody has an answer to this? I know of a service menu that can tweak the tv, is it worth it?
    Well, i'm desperate
  2. alphaomega16
    alphaomega16
    May 17, 2005
    14,033
    163
    Southend on sea
    +3,743
    Hook the VGA up to a PC Monitor and change the resolution then try it again on the TV.
    The Resolution currently set for the VGA may be higher than your TV can support.
  3. bonannogiovanni
    bonannogiovanni
    Dec 25, 2006
    19
    I already did that, from an xbox point of view, there are only three resolutions, 480p, 720p, 1080i, I tried to disable the last two, but to no avail. What about this component to vga converter, with my prevous lcd tv, it worked well
