Samsung LCD LE32M61B vs LE32M51B query
Chalky
:lease: Apologies for starting a new topic but the big Samsung owners thread is rather daunting! The only difference I can see between these two screens appears to the contrast ratio (5000:1 for the 61B vs 3000:1 for the 51B) and the cosmetics. I suspect that I'll end up turning most of the picture processing features off anyway.
The system will primarily be driven by a laptop via VGA for the time being. Will eventually get XBOX 360, possibly an upscaling DVD and SKY HD when it arrives.
Is there any compelling reason to go for a 61B when the 51B is available for less than £1k? Any advice would be much appreciated.
thanks
dllord
thanks
You might as well get the M51 like i did if you're going to turn the dynamic contrast OFF! Dynamic contrast is lame anyway! And the M51 looks sexier with that bit of silver on the bottom!:thumbsup:
dcm
the m61 has a better viewing angle of 178 compared to 170 on the m51
if i wasn't getting the 26 inch i would prob have gone with the m61 since it's not available in 26inch :(
Tef
i was browsing trhough few forums when i did research on the LE series, someone at some point mention something about 61 fixed someof the bug in the control programe or some sort
