Samsung Lcd displays pink progressive scan signal
Discussion in 'Samsung TVs Forum' started by Stiffler05, Oct 28, 2005.
Tags:
  1. Stiffler05
    Stiffler05
    Hi guys,
    When i try to play the getaway on my Pal ps2 in progressive scan the picture goes totally pink for a while and switches back to Pal. I'm using a third party component cable and a 32" samsung LE32R31. I've switched it to component in the ps2 browser too. The ps2 is one of the first silver ones to be released.
    Any ideas what could be causing this? Any responses would be appreciated.
  2. Yetti54
    Yetti54
    Haven't got a clue about this problem but got a quick question for you. (Cheeky i know)
    How do the games look on the samsung from the ps2? Have you tried Pro Evo 5?
    I'm pretty certain i'm going to get this lcd but am worried about how the ps2 will look after hereing some bad problems with it.
  3. Stiffler05
    Stiffler05
    If i'm honest ps2 games look crap. I've had some problems with rgb too, so i've been running everything through component. I think its the big difference between the native res of the tv and the res which is displayed by ps2. God of war for example looked really nice on my 24" crt, but looks well jaggy on my lcd. The main reason i bought it is for Ps3 and 360, so i'm not too fussed.
  4. DanDT
    DanDT
    Aug 31, 2005
    1,169
    63
    London
    +144
    As long as you run PS2 games in progressive scan (the ones that support it) you should be fine. I've started importing USA titles because for some reason, some titles that support pro-scan in the US version, don't have the option in the European versions (GT4 for example and many others). And importing is sometimes cheaper and much quicker. I've just ordered Shadow of the Colossus from the US, should be here soon enough.
