Question Samsung Laptop replacing hard drive question
Discussion in 'Computer Components' started by Tooms, Apr 28, 2016.
  1. Tooms
    Tooms
    Jan 14, 2014
    1,700
    116
    Oxfordshire
    +510
    Hi.
    I decided to replace the 1TB hard drive on my Samsung Ativ 6 Book with an SSD. I am fairly sure I have managed to clone the drive (you will see why in a minute) and I took it all apart, removed the hard drive, and the connector that connects the hard drive to the laptop has come away from the motherboard.
    It is a flexible connector that looks identical to this one:
    laptop SATA Hard Drive HDD Connector FLEX CABLE BA41 02200A NIKE2 15H HDD on Aliexpress.com | Alibaba Group
    The clip it goes in to is tiny, about 7mm big, there is a black moveable thing on it which appears to be a clip, but I have NO IDEA how the connector goes in to the clip or whether up or down is locked.
    Does anyone have any idea before I have to resort to taking it to a repair shop?
  2. JayCee
    JayCee
    Jan 20, 2004
    22,867
    Lanarkshire
    +2,425
    This should be in our PC forum. Ask a mod to move it.
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,414
    Norfolk
    +2,413
  4. shaz2sxy
    shaz2sxy
    Mar 17, 2016
    91
    11
    Newcastle
    +9
    Can you take a picture of it as most of them should be standard fit for 2.5" drives
