Samsung LA26R71BDX Issues with Harmony Remote
Discussion in 'Home Cinema Control & Remote Controls' started by dreggen, Jan 4, 2007.
  1. dreggen
    dreggen
    I'm having a problem with switching between Inputs on my TV as there is a different button for the TV (Digital and Normal) and Sources (HDMI, Component 1, etc). Has anyone solved this or can think of a way around it?
    Regards,
    BM
    :thumbsup:
  2. cameluk
    cameluk
    Jul 19, 2005
    36
    Whenever I used an activity, it always switched to either Terestrial or DTV, and never to Video 1,2 PC or Component.
    Using all the options on the remote for the various inputs, and noted down ones that actually worked on my TV
    i.e.
    EXT.1
    Video2V2
    Component
    RGB
    DTV
    Then under activity, set it up so that it always went to DTV, and then added an extral command to switch to the input required by selecting the option 'Send this infrared command'
