Samsung KU6000 - KS7000
Discussion in 'What Is The Best TV For You?' started by Toppo7, Nov 23, 2016.
  1. Toppo7
    Toppo7
    Nov 21, 2016
    4
    4
    Mouseville
    I've read the KU6000 is the UK version of KS7000. Is this true?
    Do they have identical specs? I was looking at buying the KS7000 - but the KU6000 is cheaper.
    I want the SUHD Mainly.
    Cheers =]
  2. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    Where in the world are you ? , the ks7000 is that in the UK , I seem to recall it is ks8000 in America ...
  3. jep
    jep
    Sep 18, 2016
    328
    46
    England
    +214
    Far from having same specs. The ku6000 is the 6 series whilst ks7000 is a 7 series (ie next model up with better specs and higher price). As paulyoung said, ks7000 is uk version of the US ks8000 (confusing I know as the uk ks8000 is the US ks9000).
  4. James C
    James C
    Mar 1, 2009
    126
    London
    +13
    As above, the KS7000 would well be worth the difference if you plan on watching HDR sources.
    As a rule, KS indicates 'SUHD' branding. I.e. 10 bit panel, local dimming support for HDR and 1000 nit peak brightness.
