BorisDG
Hello. I bought JU7500 week ago and I've noticed it that too. Also I have slight buzzing/humming noise coming from the main circuit board (where are the connections) - sounds like coil noise. It's only noticable when I put my ear there and the sound is muted. When the TV is "relaxing" is not that noticable. Probably all of this is normal and I should keep it? After all it's in waranty. Can someone with same model share his situation?I am on my second of these and both have had slight vibration on the metal frame so I assume it's normal. It's very much just a vibration and does not shock or spark or anything like that.
Thank you very much.
