Question Samsung JU6400 into 2 channel amplifier via optical
Discussion in 'General TV Discussions Forum' started by dollag, May 5, 2018.
  1. dollag
    dollag
    May 30, 2015
    1,813
    116
    Kent
    +750
    My Brother in law has a JU6400 and was looking for a bit more sound that the on board speakers.
    There is no room for a sound bar so advised getting a small pair of bookshelf speakers and a small amplifier.
    With My LG E6, I send my 2 channel amplifier a down sampled pcm signal as obviously cannot decode dolby/dts. for my bedroom, this works great.
    My question is, does the samsung have the same option?
    I was under the impression that some TV's do not allow this?
    TIA
  2. JayCee
    JayCee
    Jan 20, 2004
    23,374
    Lanarkshire
    +2,516
    Yes, that should work.
  3. dollag
    dollag
    May 30, 2015
    1,813
    116
    Kent
    +750
    Thanks for that. What do you mean it Should work? I do not want to buy the equipment and be in a situation where it does not work [emoji17]
    Can you clarify if a Samsung ju6400 is able to send down sampled lpcm via optical?
    Thanks for the help
  4. JayCee
    JayCee
    Jan 20, 2004
    23,374
    Lanarkshire
    +2,516
    Yes, it will.
