Samsung Js9000 Sony amp connection issues
Discussion in 'AV Receivers & Amplifiers' started by BobbieF, Apr 27, 2016.
  1. BobbieF
    BobbieF
    Apr 27, 2016
    Hereford
    Hello,
    I've recently bought the Samsung Js9000, and connected everything up fine using the one connect box. The only issue is that when I've used the Av adapter leads to connect my ageing Sony amp via the red and white leads it doesn't work.
    Is it time to invest in a new amp with USB? Or Digital optical?
    Or is it a setting on the TV that I need to change?
    Anyone that has an idea, or has solved this please let me know. I'd rather not have to fork out for a new amp, as I love my old Sony. But if needs must....
    Thanks!
  2. chrishi5
    chrishi5
    May 29, 2011
    240
    +12
    Buy new one
