samsung hw750 wireless question
Discussion in 'Soundbars, Soundplates & Soundbases' started by killer10971, Jul 8, 2015.
  1. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    can I use the Samsung multiroom app and take advantage of the settings without using the Samsung hub
    can I plug the bar straight into my existing network and see it with the app and control it
    many thanks
  2. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    it works perfect but I cant see its ssid or even if it broadcasts one without the hub or even if it is indeed wifi as such
    I just want to make sure it works properly
