Samsung HW-Q950T Soundbar Review & Comments
oscarmadfish
the thing is your eyes should be level with the centre of your screen . you cant do both so soundbar as near as poss to screen bottom is my set up option
Ruby
How well does that work for you immersion wise both from the surround channels and height channels built in to the soundbar?
Rev007
Its fine.as said its supposed to sit under your tv anyway.also if you have a Samsung qled tv you can add the tv speakers into the mix as well
Ruby
I don't have a Samsung TV. In my setup, the soundbar would be close to the bottom of the TV, and would be about 53cm from the ground. Do you think that would work well enough for the Dolby Atmos immersion?
If I bought one of these soundbars from somewhere like Currys, am I able to try it at home and then return if I don't like it?
oscarmadfish
i have the n950 and imo it works great
Ruby
What's the best way for me to get a home demo of this soundbar - order online and then return within 14 days if I don't like it.
Rev007
That's what few people do .not sure how it works though.i think you will find it's fine ,for your set up .
Ruby
Is there a recommended distance you need to sit from the soundbar in order to optimize the surround and height speakers effect?
oscarmadfish
a rule of thumb for me is as near centre of front and rear with the rears the same distance from my seating postion
carlosv1
I'm looking to purchase this to replace my Samsung HK N950 which I'm extremely happy with.
My sounder is wall mounted on a chimney breast with the Sub to the left of chimney would this impact sound performance on the Q950T? (apologies if this sounds a ridiculous question)
Also will it fit straight onto the wall mounts already attached to mount my N950?
appreciate any help!!
Steve Withers
Reviewer
The sub location is fine, but the Q950T uses a different chassis to the N950, so I don't know if you can simply use the existing wall mounts.
AlmostSerious
I did the same. Switched my N950 for the Q950T.
While I am happy now (with the new Firmware) to have everything working as before, I still do have the annoying sound drops. Never had that with the N950. Soundwise, the Q950T sounds a tiny bit better for the Center, other than that I don't notice that much difference.
I guess what im trying to say: If it worked with the N950, it will work with the Q950T.
Additionally, If you can upgrade for "free or almost free" definitely go for it. I was able to sell my N950 for almost the same price as i paid for the Q950T.. So that was a no-brainer for me... until i learned about the issues (like no LPCM until the latest firmware)
As to you question about mounting:
The Rear Speakers fit in the same mount as the previous Rear Speakers. For the Soundbar, itself, I actually do not know as i never mounted it, but looking in both manuals they have the same part numbers:
Wall Mount Guide (AH63-04369C)
Bracket-Wall Mount (AH61-04119A)
so should fit without a problem
Rev007
If you can afford it the new 950a is supposed to have a room calibration built in to it and 2 extra speakers .🤷‍♂️
Haiko
Randomly. I only observe it with FireTV Cube directly connected to the Bar. Doesnt matter what codec. Even with Atmos i get these 0.5s of silence in the middle of a movie. Maybe once an hour.
Oh, same like me with a FireTV4K stick. Doesn't mater what I use (Disney+, Prime). I could observe them with my Bluray player (hdmi2 in) too. So this seems to be a hdmi in port issue on this soundbar.
cashxx
Hi everyone. I just purchased the Samsung Soundbar HW-Q950T after trying to decide between it and the Nakamichi Shockwafe 9.2.4 after my Pioneer Receiver died after 12 years. The Klipsch Cinema 1200 looks interesting too. All the reviews said the Q950T. I'm not impressed yet. The LCD being on the top is driving me nuts. I decided to swap TV's today and brought my 4k TV up from the basement to the living room. The plan was to get an 8k tv at some point and that was going into the living room, but thought I spend more time in the living room why is that 4k down there, might as well use it. Well ever since the rear left speaker now has a popping sound that is driving me nuts. Not sure why the TV would make a difference, but never heard it until the swap. Almost sound like someone tapping on a microphone testing to see if it's working and happens every so often. Doesn't matter if its from the dish box or apple tv 4k. The old TV was a LG 55LW6500 and the 4k tv is a LG 55UN7300PUF. This 4k tv has PCM/Auto/Pass Through in the settings and tried each one manually, but no luck. Anyone know what this could be, not sure if I can live with it. Spoiled now on the 4k, hate to swap them.
cashxx
Think it's ok now. Unplugged speaker and plugged back in and also adjusted speaker settings to the way some listed here. Didn't hear it the rest of the night. Hope that isn't a common issue of having to reset speakers or unit for it to work correctly?
Rev007
I have to unplug my sub all the time.blue light is on but no sound.turn it off then on again its fine 😡👍
ClemensRausch
Have exactly the same setup and same issue. Annoying. I don't think its hardware related, but Samsung wants me to send it in, cause "its not an software issue"... By the way you won't get these dropouts when streaming through ARC (you lose the ability of lossless audio tho) and eARC right?
cashxx
Still doing it. I give up, it's back in the box for return. I bought the Nakamichi Shockwafe Ultra 9.2.4 and blows away the HW-Q950T for movies. The 950 has slightly better sound while watching TV and maybe surround, still testing that, but movies the Nakamichi rules with the bass. Also has the LCD in the front so you know what you are setting. So far doesn't have that tapping bass sound from the left rear surround.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
Latest News
What's new on UK streaming services for June 2021
  • By Andy Bassett
  • Published
Austrian Audio launches Hi-X65 headphones
  • By Andy Bassett
  • Published
Roku expands streaming content with Roku Originals
  • By Andy Bassett
  • Published
What's new on Netflix UK for June 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 12th May 2021
  • By Phil Hinton
  • Published
