PrMinisterGR
Is it me, or this bar doesn't have side speakers?11.1.4 ... more image elaboration? ...... definitely a good thing. Q950A sub "Space EQ"? ... at least they're trying to EQ it this time, hope it can be edited too though. And hoping they put a far better EQ on the bar this time. If they do and the firmware works acceptably I'll be very tempted to buy one.
Zoomed it in and cleaned it up some, the display has not moved, same location but looks to be longer.
Bet this ends up being the best bar based surround system in 2021.
Unless the sides are fabric/transparent, it seems a bit weird, as the 11.1.4 support means it has Side+Wide, and I cannot see them anywhere. Or perhaps this bar is a lot wider than the Q950T. It gives me LG-wide vibes.
EDIT:
The company’s flagship soundbar features 11.1.4-channel audio and Dolby Atmos. The HW-Q950A will come with a 7.1.2-channel soundbar (with two height channels) and a separate 4.0.2 channel wireless speaker package that has side-firing drivers in addition to the top and bottom-firing drivers.
Samsung's new soundbars come with improved audio, Alexa, and AirPlay 2 - SamMobile
It really depends on how the Xbox/PC send the signal. At this moment, you will not get Atmos in games, as of Dolby Access 3.7 (on the PC). This won't change if you plug the PC directly to the bar or to the TV.Thanks , great for you to reply.
I'm looking to get a LG 55CX or 55C1... console will plug straight into the tv, would that allow me to use Atmos in the games ?
Funny thing is, even though "Atmos" is not engaged, the computer still sends upward firing audio that actually sounds like Atmos. Can't wait for the firmware update.
