PrMinisterGR
But then you would have to trust them that it actually does what it says.Good question. If next years model can passthrough HDR+4K+120hz then I might have to bite the bullet....
Regular DTS will not show up on the display however DTS:X always shows up for me via disks. It's possible that the file you downloaded is not truly DTS:X. Another way to test is when an Atmos or DTS:X source is being played you will not be able to change the sound modes.Just got my Q950T. Interestingly, my unit seems to be manufactured in Oct/Nov and it comes with 1017.5 firmware installed out of the box (based on Smartthings app > soundbar > Information).
I have some questions which I hope people who are more knowledgeable than me can help.
1. When playing DTS audio formats e.g. DTS-HD MA, is the status display on the top of the unit supposed to show DTS-HD or something like that?
My movie collections are mostly in DTS related audio format, and when I played few of them to test (via Kodi 18), the status display did not show anything at all.
I played Dolby Atmos clip from Dolby Access app in Windows 10, and the status display showed Dolby Atmos.
I tried DTS:X file I downloaded from internet and played it, also didn't show anything.
Any ideas?
My HTPC is NUC i5 from 2014
Windows 10, installed Dolby Access to be able to configure Atmos
Kodi 18, set Audio and passthrough device to WASAPI, channel 7.1, turn on all audio formats under Passthrough section
The NUC is connected to HDMI 1, then my TV ARC is connected soundbar HDMI Arc.
Currently, using Adaptive Sound mode.
2. Related to number 1, is there a way to find out what audio format it is currently playing? I cannot see it in Smartthings app..
3. What mode do you use for best sounding experience?
I watched a reviewer said Adaptive, but then I saw PlanetaryReference user's "scientific-based" preset for Surround mode (doesn't apply/work for Adaptive mode?)
4. I know for now LPCM is not supported, so not ideal for gamers out there.
Just wondering for PS5, can't you simply choose Bitstream Dolby to get multichannel (lossless?) sound?
According to PS5 FAQ blog, it supports Dolby True-HD.
Is bitstream sound noticeably worse than if it's using LPCM?
5. Is there any minimum gaps I need to be aware of when placing the subwoofer?
Thanks !
I tried a couple of downloaded files and only 1 Atmos MP4 was working and showed Atmos in the display. I couldn't find any DTS:X file in the Internet.I tried DTS:X file I downloaded from internet and played it, also didn't show anything.
Yes. The q950t has better sound quality. I found the sn11rg to be lacking in the midrange and inconsistent during action scenes (explosions didn’t always hit). It was reliable, had lpcm support, and had a good immersive bubble. On pure sound quality though the q950t was a pretty big step up for me.Is there any way to play Youtube Music via Wifi, not Bluetooth?
Or streaming music via wifi only work with Amazon Music and Spotify?
Audio quality when streaming music via wifi is much better than via Bluetooth, I tested.
I noticed that LG SN11RG supports google assistant and that definitely opens up more stuff..
Contemplating to switch to the LG now (not to mention LG supports multichannel LPCM unlike Samsung one), but unsure if the sound quality is comparable / as good as Q950T.. from I read Q950T has a better sound quality?
Step up from the sn11rgThe Q950T is a pretty big step up compare to SN11RG, or you meant big step up from your previous soundbar (not sn11rg)?
One factory reset later and music playback via the built in Alexa and amazon music is again working with the surround and adaptive modes across the rear speakers.. Phew!Another day another Samsung quirk.. so, acoustically the kit is great but the software makes me die a little more each day.
I tried the built-in Alexa again today to play some music from my Amazon Music Unlimited. Plays okay, excepting that there are still short drop outs, but I also determined that the Sound modes don't work properly when doing this, e.g. the upmixing when using "surround" or "adaptive".. rear speakers don't work.. if I play music from my nvidia shield with the same songs (stereo mp3 rips from my cd originals) using the same sound modes, all good!
..so, another implementation fail from Samsung..
So frustrating the software is so buggy when the hardware is ace!
Usually unplug the power cord is enough. So I can keep my settingsOne factory reset later and music playback via the built in Alexa and amazon music is again working with the surround and adaptive modes across the rear speakers.. Phew!
..it does suck that factory resetting is needed when things like this happen but at least its relatively quick to do![]()
Any ideas?
Thanks !
Is there a way of limiting the soundbar volume? Twice this evening my fat fingers have hit the volume bar in the app and pushed the sound to 100 and it scared the dog to death
I'm using the app too to control the volume. But in general by a scenario and I have put a widget on my home screen. By that I'm avoiding to increase the volume too much.Is there a way of limiting the soundbar volume? Twice this evening my fat fingers have hit the volume bar in the app and pushed the sound to 100 and it scared the dog to death
Thanks, just did the same. Shame you can't set it to change the modes as well. But at least my dig is now safe.I'm using the app too to control the volume. But in general by a scenario and I have put a widget on my home screen. By that I'm avoiding to increase the volume too much.
View attachment 1438558View attachment 1438559
Thanks , great for you to reply.eARC supports the exact same formats as the normal ports. The question is more what your TV supports.
Lacking LPCM is kind of a big deal as to get proper multi-channel audio you must ensure that the bar always gets a bitstreamed format. It seems to cause issues mainly with gaming up to this point, but setting the audio output of my PC to "Atmos for Home Theater", seems to ensure a bitstreamed format is sent. I do the same with my PS4 Pro by setting it to "DTS".
LPCM would be desirable as devices like the PS4 Pro don't have non-lossy alternatives to DTS/DD+. It would also make future compatibility with pretty much everything a breeze. I don't know how the Series X behaves, but other people in this thread might. I suspect it's not that much different than my PC, so setting the output to "Atmos for Home Theater" might do the trick for you. The best way to know is to check yourself or ask people here.
It's also a good idea to know beforehand how you would prefer to have the equipment setup.
In my case, I want everything plugged on the TV, and then the TV to just forward the audio as it comes to the soundbar. Until Samsung enables LPCM and Dolby/Microsoft fix the mess they did with Dolby Access, that is a bit unfeasible. It might also be unfeasible with TVs that don't support DTS, but in that case I think that a dedicated media player directly connected to the bar is the best way to go.
